1 of 5
Wyze Sense Climate Sensor
Tracks temperature and humidity.
⚠️ Requires Wyze Sense Hub.
This device will NOT function as an individual or standalone product or with Wyze Sense v1.
Size
Low stock: 46 left
Wyze Climate Sensor is designed to be used with Wyze Sense v2 from Wyze Home Monitoring.
Place Wyze Climate Sensor in any room to track temperature and humidity throughout the spaces in your home with the Wyze app. With a 500 ft range, easily position it in distant rooms, basements, or attics. It's unobtrusive with a sleek, white design to blend into any environment. Set it on any surface or use the peel-and-stick adhesive backing for walls.
