Wyze Home Monitoring Service Updates
What We Are Developing
  • Sharing the monitoring experience with other Wyze accounts
  • Professionally monitored freezing and leakage hazards
  • Support for Chime in Home Monitoring Service
  • Emergency Contacts
Can’t find the feature you wish to have? Join the survey and give your feedback!
Release Notes
Oct 13, 2021
App 2.25
  • Added Monitoring Schedule in Home Monitoring for routine arming and disarming convenience without using the Keypad or your phone
Sep 22, 2021
Sense Hub firmware 4.32.5.92
  • Fixed a bug that caused some hubs to turn off immediately after the Hub is unplugged from power
Sep 16, 2021
App 2.24.52
  • Added Trends for Wyze Home Monitoring to show how you use the service to protect the things you care about
  • Added support for Wyze Home Monitoring users to change names in Monitoring Settings after setup
  • Lifted the mandatory keypad + one sensor limit for Home Monitoring Sense Hub setup
  • Added the ability to set up Wyze Home Monitoring from the Home tab Add Device page
Sep 8, 2021
Sense Hub firmware 4.32.5.80
  • The PIN is now required to switch to enter Disarm Mode from the keypad
  • Added a fast beep for Entry and Exit Delay
  • Fixed a bug that caused some delayed false alarms for some people
  • Security improvements
Sep 1, 2021
App 2.24.36
  • Home Monitoring added support for Leak and Climate Sensors status visualization
  • Added support for Wyze Leak and Climate Sensors for Wyze Home Monitoring
Aug 4, 2021
Sense Hub firmware 4.32.4.295
  • Added active sensor activity to Monitoring Events
  • Added a toggle for the entry/exit delay countdown sound
  • Added a chime notification sound when on-duty sensors are triggered upon entry
  • Improved the offline Hub audio notification experience
App 2.23.21
  • Added support for Wyze Leak Sensor
  • Added support for Wyze Climate Sensor
Jun 10, 2021
Sense Hub firmware 4.32.3.183
  • Improved Hub offline performance
  • Optimized sensor function reliability
  • Improved the Hub countdown experience
Jun 9, 2021
App 2.21.33
  • Added a low battery indicator for Wyze Sense v2
Apr 6, 2021
Sense Hub firmware 4.32.2.127
May 12, 2021
App 2.20.142
  • Added support for phone numbers changes in Wyze Home Monitoring
Apr 7, 2021
App 2.19.24
  • Fixed a bug that caused the camera to trigger false alarms for Wyze Home Monitoring
Mar 24, 2021
App 2.18.43
  • Added support for Wyze Entry Sensor v2
  • Added support for Wyze Motion Sensor v2
  • Added support for Wyze Sense Hub
  • Added support for Wyze Sense Keypad
  • Added support for Home Monitoring Service
Dec 15, 2020
App 2.16.23
  • Added the Home Monitoring tab
